04-28-2006 11:11 PM
04-29-2006 12:52 AM
04-29-2006 01:18 AM
04-29-2006 05:35 AM
After the sort operation, the elements are ordered from lowest to highest. Accordingly, the N lowest elements are the N first elements. You just need to wire the length input since the index inpuit default to zero.
If you look with some attention into the array subpalette, you will found that the Array Size function is the very first :O.
Seems that you need to spend some time to get familiar with the most basic LabVIEW functions 😉
05-03-2006 10:34 AM
05-10-2006 04:46 AM
05-10-2006 08:37 AM
05-10-2006 11:52 AM
05-10-2006 12:13 PM
