Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
02-14-2019 02:10 AM - edited 02-14-2019 02:12 AM
I have a crio9035. Every time I use it, I need to manually deploy it on labview and run RT MAIN manually. Is there a way to automate these two steps?
Thanks!
02-14-2019 02:55 AM
Using the project window build your application, deploy and set to run at startup on the RT operating system.
Create a build and use the right click menu to deploy with the appropriate option.
We'll be in touch soon!
