audible alert to indicate the occurrence of an event using lvsound2.dll
I'm fairly new to LabVIEW, but not new to programming.
I'm trying to implement a VI which gives an audible alert to indicate the occurrence of an event using Play Sound File.vi.
A .Wav file is set to be played, after a certain flag is tripped to indicate the occurrence of an event. While my VI works well before compiling, it does not give an output after compiling. I cannot seem to get the same performance once the code is compiled as a Source Distribution (as a .llb, which is what I want) or as an Executable.
I have attached a sample code where I have replicated the problem. In the sample code I have assumed the event has occurred (flag tripped) and set the .Wav file to be played until the flag is reset. I gather this is probably not the most elegant way, but I'm trying to understand why compiling the .VI stops the sounds being played.
Any thoughts/comments are greatly appreciated.
Message 1 of 8
(2,880 Views)
t works when I compile it.
Message 2 of 8
(2,849 Views)
Thanks for that, Paul. Did you compile it as an executable? or as a Source Distribution?
Message 3 of 8
(2,826 Views)
If you want help with turning this into a DLL, attach the project you're working with and a calling VI to show an example of how you wish to call it.  Without that, we can't tell what isn't right.  We can only take the steps we'd take.
Message 4 of 8
(2,820 Views)
I compiled it to a .exe
Message 5 of 8
(2,809 Views)
Thank you, natasftw.
Please see attached.
Message 6 of 8
(2,786 Views)
Thank you, paul_cardinale.
Compiling it into an executable seems to work for me too. However, it doesn't seem to work when I compile it into a .llb (Source Distribution). I need to compile it into a Source Distribution as I use this VI through another application (also developed in LabVIEW). I can recompile the application if necessary.
Message 7 of 8
(2,785 Views)
Accepted by topic author hkd2015
Fixed.
It seems I made a mistake in the files path of the support directory structure, when compiling as a Source Distribution (which may have prevented the lvsound2.dll being accessed).
Message 8 of 8
(2,757 Views)
