appropriate set-up commands for a Mettler pH meter with LabVIEW 7 Express
I am using the DAQ wizard to set-up a reader (VISA) for a Mettler pH meter. The DAQ wizard requests several commands that must be sent to the meter.
Mettler did not provide this info. Can anyone help?
Thanks.
(2,544 Views)
I think Mettler normally provides the information, try contacting a local office and ask them if you can have the information you need. It's normal to allow people with other software to be able to interface with a pH meter, so I think the chances are quite good that you'll be able to get the information direct from Mettler.
Hope this helps.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,542 Views)
