02-29-2012 01:06 PM
I am trying Write to an Excel file in the Specified Columns and rows that is on my excel Template sheet. It does it correctly the first time but it stops and give an error. Can anyone help modify this code in labview 2009 to allow me to be able to save the recording every 30 seconds or what ever time frame I specify and append down in the right column and row please.
Solved! Go to Solution.
02-29-2012 01:51 PM
Use 'Elapsed Time' VI instead of your timing logic, which will auto reset after every specified time.
03-01-2012 11:53 AM
Also, as far as appending your data to the excel document in the right location, you need to use the MS Office parameters input for the Append Table to Report function.
I wrote an example previously on how to automatically append to the next available row using the report generation toolkit, you might check it out and adapt its concepts to your code:
https://decibel.ni.com/content/docs/DOC-21326
03-01-2012 01:20 PM
Thanks!
