hello
Yeah. there is no much confusion.
but the sample to read from the buffer is making me confuse. now if i
have 2 channel of acquisition of analog signal, as i said each channel
set to 1000 samples to read, the buffer size is automatically set to
2000, am i right? if i set the sample to read from buffer is 1000, then
will it mean that it takes 1 second to retrieve data from buffer for
these 2 channels?what if i put 1000 samples to acquire, sample to read
is 2000?
will it be possible if the number of sample to acquire change
dynamically?for let say, it gets from the sample of digital line. due
to the lagging issue arise from the analog signal, the samples from
digital line is delayed to be read and only for the subsequent
signal(but not for the real signals that analog signal should be
acquired).
to simplify the explanation as below
i give an example.
1st case
digital signal gets sample of number 1000, it will be sent to sample to
acquire in analog acquisition vi.then sample number to read from buffer
is 1000. it will be ok
2nd case
if the digital signal gets sample number 6000, logically it will be
sent to sample to acquire in analog acquisition vi.then sample number
to read from buffer is 6000. but i find that it was delayed to be sent
to analog acquisition vi. in analog signal it chooses the default value
1000 as the sample number to acquire due to the delayed sample number.
The sample number 6000 will only be sent to analog signal acquisition
vi for the next signal. then it mess up the sample to be read
i hope u can understand what i am trying to explain what the problem exist
thanks
