app_view disappears from my RunTime application
Labview 8.2.1. When I build an executable of a Vi in which I specifically delete one of the app_* menu (the Labview reserved menus) using Delete Menu Items, the VIEW menu disappears in all cases from the executable even if I delete whatever menu like Tools.
The only way to leave the VIEW in the application built is to leave all app_* menus which I do not want. As soon as I delete a menu (other than VIEW), the VIEW menu is no more in the built application.
Thanks a lot for your help,
Christophe
(2,750 Views)
Create a custom menu and use "Edit->Insert Application Item" to insert the entire VIEW menu in the custom menu. Afterwards save and replace default menu on close.
André (CLA, CLED)
(2,708 Views)
Thank you for your answer, André. I understand what you mean but the reason why I would like to keep the View menu is that it lists all the opened Windows (all the subVis that are opened) at a certain time. So this peculiar behavior is not easy to reproduce by creating a custom menu, copy of the original View. I just wonder if this is a desired behavior thought by the developers or if it is a bug...
Christophe
(2,705 Views)
