anti aliased
I need some detailed explanation about the "anti aliased" function included with the waveform graph. I couldn't find a good one in the documentation and it seems to be imposible to disable it. Thanks in advance.
gs
(2,730 Views)
Anti-aliasing.
Short version - using some display tricks to make jagged lines (in this case, the plot line) appear smoother. The downside is that it takes up CPU power.
An example can be seen on the right side of this image:
When you see it in its real size, the image on the right looks better.
___________________
Try to take over the world!
(2,714 Views)
By the way, I don't think you should have any trouble disabling it. Can you upload an example VI where it can't be disabled?
___________________
(2,712 Views)
