Ross;
You can just right click at the channel and create a constant. That constant will refer to the AO channel. Don't forget to set the device number as well (the default for that VI is device 0, you need to change that to match the device number MAX assigned to that board).
If that doesn't work, I believe the first step for you is to run one of the examples which ships with LV, for analog output. One you can try is "Generate 1 point at 1 Analog Output.vi". That vi can be found at Serach Examples->I/O Interfaces->Data Acquisition->Analog Output->Single Point Analog Output.
If the same error occur, you can test the Analog Output on MAX (use test panel, go to the Analog Output tab and generates a sine wave there). If you see the same error on MAX, the problem is probably r
elated with the board installation or the Analog output channels is damaged.
After those tests, you can try to uninstall and reinstall NI-DAQ to see if the problem is fixed.
Hope this helps.
Filipe
