08-10-2009 09:50 AM
Hi all,
I want to output a sinusoidal signal with the soundcard of my PC.
For measuring the output signal, i use the NI DAQ USB 6009.
My Problem is: Whenever I start the VI, there is always a phase shift between the internally digital sine wave and the real externally generated analog outputsignal. The phase shift changes and is different to another moment.
Please help me.
08-10-2009 10:06 AM
Control the phase of the output on the sound card ..... Is it possible?
If not try using an output on your DAQ device.
Ben
08-10-2009 10:06 AM
Your daq unit and the sound card is not synchronized, hence the phase shift. Your approach will never work. What are you trying to do? Maybe I can give you some pointers if I know more about your application
