am working on a project which involves using labview and data acquisition device 6008 and a gps moodle,how can i get it done?
I never used usb 6008 but I can tell you that also you need to understand the data which is sent from GPS, I am sure you also need to understand the logitude,latitude and other stuff calculation needed to perform on the GPS data becasue you need to make all the GPS parameter to user . Once you got that, you need driver for DAQ then acquisition is simple.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 17
(1,020 Views)
--Ranjeet
Message 12 of 17
(1,020 Views)
Hopefully the GPS should be easy since there is a well-defined standardized output format.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 13 of 17
(1,013 Views)
Seems like a bit much for two weeks.  Sheesh.
Bill
CLD
(Mid-Level minion.)
Message 14 of 17
(1,001 Views)
If he knows. its very less work. Nothing much just acquisition and display
--Ranjeet
Message 15 of 17
(995 Views)
it is a 3D accelerometer, and am using a TK103 gps moddle, labview software, USB 6008 and a 5V potientiometer...
Message 16 of 17
(985 Views)
The TK103 is going to be difficult to use as it only sends location data out via its built in modem, it doesn't have a way to send location data out via serial/ USB which would be far easier to integrate with your laptop. Whilst it is possible to get Labview to send a message to the TK103 and parse the response via GSM/ SMS there will be delays in send/ receive so it certainly won't log true position with good accuracy, your laptop would also require a modem via mobile phone connected in order to use the TK103.
What is the 5V potentiameter measuring?
 - Mike
Message 17 of 17
(981 Views)
