additional xilinx compilation tools dvd
It's not corrupted on the server that I have access to... I'm working to get the version on the deployment server taken down, and the correct version uploaded. Thanks for your patience. Again, if you need the tools immediately, ni.com/support will be able to provide them for you. I sincerely apologize for the inconvenience.
Cheers!
TJ G
Message 11 of 20
(3,785 Views)
Using the DVD from 2012 DS1 is much faster than to download 1.8G!!! Thanks!
Michel
Message 12 of 20
(3,698 Views)
Hello everybody,
I tried to install LV2013 DS2 and I have the same problem.
I cannot find any DVD that is recognized as the correct 'Additional Xilinx compilation tools'
I tried the following package downloads:
- "NI LabVIEW 2013 FPGA Module Xilinx Tools 10.1" downlodable Here
- "LabVIEW FPGA Module Xilinx Tools 10.1" downlodable Here
- "LabVIEW 2012 FPGA Module Xilinx Tools 10.1" downlodable Here
None of them worked, so I had to install xilinx tools using update service.
Is there anyone that installed those tools from a National Instruments portal download?
Thank you,
Message 13 of 20
(3,012 Views)
That DVD is only shipped to you if you have a current SSP with the LabVIEW FPGA module.  Depending on your license setup, it could be shipped seprately.
Message 14 of 20
(3,004 Views)
We currently have an SSP with the LabVIEW FPGA module, and we have not received yet the physical DVDs for LV2013, so we decided to download DVDs directly from the portal.
We were able to install the LabVIEW but 'additional xilinx compilation tools dvd' is asked during setup, is there any download available from National Instruments site of this DVD or we have to wait for the physical DVD set?
Message 15 of 20
(2,990 Views)
Please access the following link to download xilinx compilation tools:
Which Version of Xilinx Compile Tools Do I Need to Compile My FPGA Code?
https://www.ni.com/en/support/documentation/compatibility/19/compatibility-between-xilinx-compilatio...
Luis S
Application Engineer
Message 16 of 20
(2,978 Views)
Hi all,
  I had the same problem, i had downloaded the "Xilinx Compilaion tool" but when i selected the folder where i unzipped the data (when "Insert Media appear") i got the following message "The specified folder does not contain the correct volume".
  can you please give me some help on this side. ASAP please
 AS
Sagemcom,corporation.
Message 17 of 20
(2,625 Views)
Hi Saketa,
You can download the compilation tools from the following link. The link will be in the related links section (Bottom of the page) and you will need to be signed in with your National Instruments profile to be routed directly to download page:
Luis S
Message 18 of 20
(2,616 Views)
This link is broken.
"HTTP Web Server: Lotus Notes Exception - Entry not found in index"
Message 19 of 20
(1,949 Views)
Below is the link that Luis was talking about.
Compatibility between Xilinx Compilation Tools and NI FPGA Hardware
If you have an active SSP and a network connection, you do not even need to install the Xilinx tools, since they are rather large. You should be able to access the ni cloud compiler free of charge as well, which may work for an immediate solution which does not require installed Xilinx tools to compile FPGA code.
Compile Faster with the LabVIEW FPGA Compile Cloud Service
https://www.ni.com/en/support/documentation/supplemental/14/compile-faster-with-the-labview-fpga-com...
Best,
Shamik C
Message 20 of 20
(1,935 Views)
