adding white noise to signal
I am trying to figure out how to allow a user to add white noise to a signal, the idea is that the user would enter the noise ratio in db which I would then apply to a signal measurement before displaying it. I looked at the add gaussian white noise vis in LV but I am not sure how to go from the noise ratio that the user enters to the seed and standard deviation inputs for the function.
I tried to look online but all I found was ways to add noise based on amplitude, is there a way to convert from the db ratio to amplitude given that I do not know the amplitude information of my original signal before hand since it is being sampled in real-time.  Any information about this would be greatly appriciated i realize that I might be mis-understanding the way signal/noise processing really works.
Thank you,
(2,857 Views)
Well, you certainly need to know the signal amplitude if you want to create a specific signal to noise ratio.
Are you going to add a random value to each point of signal or will you have a block of signals at a time? You could set the amplitude of the noise based on the average of some previous values or base it on the full scale range of the receiver.
Lynn
(2,853 Views)
dB is a dimensionless relative measure, you need a reference intensity in order to calculate it
Often times in electronics you see things referenced to 1 mW,  called dBm = 10 log10(P / 1mW), so P = 10^(dBm/20)
http://en.wikipedia.org/wiki/DBm
For sound dB SPL = 20 log10(I / I0), I (intensity) is usually expressed  Pascalls  I0 is nearly always referencec to human hearing threshold, which is 2 * 10^-5 Pa.   Multiply by your mic gain to convert to from pressure to volts.
(2,835 Views)
For the first implementation, I will have the full signal provided to me which I will then allow the user to adjust the level of noise they want to add to it.
So form this would i be correct if I try to get the average amplitude of the signal full signal and use that for the ratio?
(2,798 Views)
You or your user need to decide if that is "correct." It seems like a reasonable starting point to me.
Lynn
(2,791 Views)
