add text file to my project
@ghamm03 wrote:
Application Directory is not in my function list
Then you are using LabVIEW 8.x?  If that is the case, then use Current VI Path followed by Strip Path called twice.  That will give you the folder of your application.  In the development environment, it complicates things just a little bit since you need the file to be relative to the VI creating the path.
Message 11 of 11
(513 Views)
