add text file to my project
I'd like to create a Log file. I know how to do it by including the path of the log file "c:/......" it works on my pc. However, my programm will run on a machine which has no C directory. I could make it work by putting it on a usb key and plug the key on the machine but that's not the idea.
So i would like to know how to add the file in project (or in dependencies maybe) to make the screen work. Actually i get the error "LabVIEW:  The path is empty or relative. You must use an absolute path."
Thanks in advance
Message 1 of 11
(5,173 Views)
Hi ghamm,
you could open a dialog to let the user choose a path.
Or you could read a known folder path using the GetSystemDirectory function (like "user documents" or "public documents")!
Just using a filename without any file path will never work…
Message 2 of 11
(5,163 Views)
Accepted by topic author ghamm03
Good suggestions from Gerd. The File Dialog express VI is surprisingly useful if you want to pop up a dialog.
Another approach is to use the "Application Directory" function, which returns a path to where your project is stored (where your executable is stored in a built exe). You can then build a path using that.
Ian
LabVIEW since 2012
Message 3 of 11
(5,159 Views)
Thanks for your answer,
I can't use the dialog box, my programm open it at each loop of my for.
I open the file in my controller.vi to add logs then i close the file and i reopen it in my View.vi to display what has been saved.
I'll try the second option on the machine as soon as possible
Message 4 of 11
(5,140 Views)
Hi ghamm,
Nobody said you should ask for a folder inside a loop!
Usually you only ask once before the loop. And even better: usually you also store settings in additional files so the user does not have to choose the very same folder with each start of your VI…
So you write to the log file in one place of your program and you read from the very same file in a different location in your program? Does this sound like a "good" option?
Message 5 of 11
(5,134 Views)
You're telling me to store settings in additionnal files when i said that i couldn't use files because i can't find them from the machine..
And how it should work ? One vi to display all the logs from the launch of the machine, 1 vi to add the newest actions.
Message 6 of 11
(5,099 Views)
Hi ghamm,
Why can't you use files?
In your first post you said you want to create file so I guess you CAN use files!?
Message 7 of 11
(5,097 Views)
I can create and use file only if they are link to the project, i can't have a path like "C:...." The machine is really basic, it can't get something on the server
Message 8 of 11
(5,089 Views)
Application Directory is not in my function list
Message 9 of 11
(5,088 Views)
Hi ghamm,
Check the file path constants
Does your "machine" have any local storage?
Then you can/should use it - all you need is to determine the correct path!
Message 10 of 11
(5,085 Views)
