04-28-2008 07:57 AM
04-28-2008 08:03 AM
Hi Toni.
It depends on what You are going to accomplish:
If You want to let the SubVI finish before the LED is updated in Your Main.VI, You just need to connect the indicator to the connector Pane.
If You want to see the LED status in Your Main.VI while the SUB.vi is running You need to use af refenrence.
Could You post Your code. It would make it a lot easier to help You.
Regards BCL
04-28-2008 08:11 AM
04-28-2008 08:22 AM
hi BCL
thanks for your quick reply
what i want is to see the LED status in the Main.VI while the subVI is running , I hope this Code will help
04-28-2008 08:23 AM
04-28-2008 08:43 AM
04-28-2008 08:43 AM
Hi dctoni.
Unfortunately i'm on a LV7.0 right now, but see the attached example......
It should be helpful.
Regards BCL
04-28-2008 08:45 AM
hi GerdW
do u know if there are a free beginner courses in germany ?
04-28-2008 08:46 AM
Hi Mike.
I saw You beat me to it.......
Regards BCL
04-28-2008 09:15 AM
