I'm trying to add a Modbus i/o server to a project. I have LV 2010 with the DSC module.
I go into my projuect, to the appropriate library, right click ->New -> I/O Server -> Modbus.
At this point, I expect the Modbus server dialog box... instead, nothing happens. The library window flickers for a second, as if the focus is elsewhere, and then it just goes back to the library.
I will note that I can do this exact same thing through the NI Distributed System Manager (adding a process to localhost) and it works fine. But, I'd like to have these Modbus devices incorporated into my project. The help file indicates that this should work.
My main concern is coming up with a way that all the details of the modbus controllers can be saved so I don't have to recreate them manually if I have to migrate to a new host machine.
thanks for any help.
mike
