add a vert and hor. scroll text box to diagram panel
How do I add a text box(with hor. and vert. scroll to diagram panel? I can use it for documenting my diagram
(2,779 Views)
Hi Trout,
You could use a string constant with scroll bar visible. This would only give a vert scroll and it's not exactly a text box but it would probably do the job.
Hope this helps,
Nick
(2,779 Views)
Hi Trout,
Another good way to add documentation to your program is to use the built-in VI documentation. Go to File->VI properties and choose Documentation from the list. The description you add here can be read through the context help later when the mouse is over the VI's icon.
Hope this helps.
Kristi Hummel
Applications Engineer
(2,779 Views)
