09-29-2011 09:41 AM
I need to add a file to an llb. The llb belongs to a sub-lvlib. (ie when I open an existing file from the llb I see [library name]:[library name]:[vi name])
I'm pulling my hair out trying to get this done. When I look at the llb with llb manager the new vi is in the llb. When I open the sub-lvlib, the top level lvlib opens, and the llb appears as a virtual folder to the sub-lvlib, and the new vi is not shown. I have a guess at what I need to do, but before I spend more than an hour trying to do it, I'd like to run it by you folks.
1) remove the sub-lvlib from the top lvlib
2) remove the llb from the sub-lvlib
3) convert the llb to a directory
4) create a new lvproj and add all the files of the llb to resolve conflicts
5) create the updated llb
6) add the llb back into the sub-lvlib
7) add the sub-lvlib back into the top lvlib
I know I'll struggle with creating the updated lvlib's. I have an lvproj for each of the lvlib's, I think I originally needed the lvproj's to help resolve the conflicts before creating the lvlib's the first time.
Maybe I shouldn't need to remove the sub-lvlib from its parent before adding the updated llb?
09-30-2011 05:55 PM
Beaver
So let me make sure I am understanding what you are asking, what you are tying to do is add a library to an existing library. It seems like the process you described should work. I would recommend trying it and if it doesn't compile then we can look at the possible causes.
Good luck
Beau H
10-01-2011 05:33 AM
10-03-2011 11:35 AM
Beau:
I'm trying to add a vi to an existing LLB. The LLB belongs to a Library. That Library belongs to another Library.
Mike:
I almost pre-empted your question when I submitted the original post ... the majority of the LLB comes from a third party, and that's why I'm continuing to use one.
10-03-2011 03:11 PM
Hey Beaver,
Hopefully I have a good grasp of what you are trying to accomplish but if I have made any wrong assumptions please let me know. A nice way of adding a VI to an existing LLB is to simply open up the VI in Labview and then select "Save As". When prompted for a save location navigate to the LLB file and save a copy of the VI within the LLB. At this point you must navigate to the Project Explorer for your project which contains the 2 nested "lvlib" files or simply open up the top library file by double clicking it in windows explorer. Right click on the sub-library and select Add»File. Navigate into the LLB file and you should be able to select any VI contained within the LLB. Hope this helps.
