12-15-2014 11:08 AM
I have a VI including an activeX controller for a Thorlabs MG17 rotation stage which was working on my previous PC, but now it is not.
I cannot select the MG17 controller from the activeX controller list when I try to add an activeX object into my container. I've tried moving around .ocx and .dll files from the Thorlabs downloads but to no avail.
I understand that this might be because I am running on Windows 64-bit, instead of 32-bit.
Is there any way to get this to work other than switch back to 32-bit Windows?
Kind regards,
Graham
12-15-2014 12:39 PM
Kind regards,
Graham
I would hope that you installed the Thorlabs software on your new PC instead of merely copying over DLL and OCX files.
12-15-2014 01:01 PM
Of course.
I then checked both PCs to see where they had put the files. The old PC has them in Program Files/National Instruments/shared/USI/Bin, however the new PC has them in Program Files/Thorlabs/APT/APT server.
I could try a re-install of the Thorlabs software, but it'd be nice to know if it doesn't work on the 64-bit machine.
12-15-2014 02:26 PM
Best asked of the manufacturer.
01-30-2015 10:27 AM
I am having this same problem, and was wondering if you were able to resolve it if you could post how it was resolved. Thanks!
02-04-2015 10:32 AM
I am taking a look into this for you. Could you please let me know what software it is that your referencing exactly? i.e. the specific driver download or software download.
This should help me refine the possible answers for you.
Gavin
02-04-2015 10:34 AM
I contacted Thorlabs about the above problem and this was the reply:
"If you have recently upgrade to a 64bit machine or Labview platform then you will need to ensure you have the correct installation of APT installed on your machine to make sure the ActiveX components are visible. Please visit the following page for the versions available, please select the one that suits your setup, it may also be worth removing the other version you have before installing any of these
http://www.thorlabs.us/software_pages/ViewSoftwarePage.cfm?Code=APT"
I haven't had time to try to repair it but hopefully this might help you?
Kind regards,
Graham
02-13-2015 01:17 PM
I figured out this problem. It seems that you have to match the version of Labview and the Type of OS you have for downloading the correct driver. It was that simple. I had originally downloaded the driver for 32bit Labview and 64bit OS, when in fact it was 64bit Labview and 64bit OS. That is why there are 4 different drivers, it seems to matter.
08-24-2015 08:56 PM
As krp15 said, it was 100% confirmed base on my experience.
I used 64-bit OS but 32-bit Labview.
The MG17 ActiveX wasn't activated if you installed 64-bit APT.
After installing 32-bit APT for 64bit OS, everything was going fine.
08-03-2016 08:21 AM
Thanks a lot for solving the problem.
