04-01-2009 08:41 AM
I´d like to use an active X object with a program to see my USB camera alive. I don't know if it is possible, does anyone could help me to do it?
I have a program to use with my camera but I don't know what object I have to insert in the Active X container to play it.
It could be another program, you suggest.
I tried another solution before but it didn´t work: http://forums.ni.com/ni/board/message?board.id=170&message.id=397511
So I thought it could be done in this way.
Thanks in advance.
Celia
04-03-2009 12:47 AM
Find attached the vi for acquiring the image from webcam taken from the forum.
Post back for queries.
04-15-2009 01:25 PM
Thank for your help, but it didn´t work.
But I've got a way using Imaq, it is an attchment. The difference from the others is the Imaq USB PropertyPage.vi. Even if I cancel the dialog box it works, but it don't work if I don't use it. As I don´t want the dialog box opens I am figuring out how to eliminate the Imaq USB PropertyPage.vi, what kind of configuration i have to do...
Thanks again,
Celia
