03-09-2007 06:20 AM
03-09-2007 06:49 AM
03-09-2007 07:32 AM
Hi Ton
thanks for replying, the trouble with not recording time is that anyone openning the acquired data will not know the sample rate. I could record the sample rate in the data set comments but people would have to know to look for it.
Regards
nick
03-12-2007 06:08 AM
assuming you've read the information here :
http://zone.ni.com/devzone/cda/tut/p/id/3539
then there shouldn't be much of a problem. The initial start time and dt are stored in the tdms along with the channel data as attributes, rather than a separate channel, but if you wanted to create one yourself, then you could generate the data for the channel programatically.
Notice how in figures 2 and 3 of the above link, the write is done from the signal data type, and the read is bringing back waveform data automatically.
Hope that helps
Sacha Emery
National Instruments (UK)
03-12-2007 09:40 AM
