07-28-2011 10:58 AM
There is an Express VI called Align and Resample. Sample at the higher rate and use that to get the "other" rate.
07-28-2011 11:08 AM
@Roro8989 wrote:
OK but I have only 1 channel and I would like to record this channel with two differents rate in the same time. I haven t multiple channel, just one.
Thank you very much
Romaric GIBERT
Then you really should have mentioned that you were using the other 3 channels of the board for something else. The decimate function or Express VI that Ravens Fan mentioned are your options.
07-28-2011 12:07 PM
Thank you very much
Romaric GIBERT
ONE channel means ONE rate at a time. It's like you're asking how to drive one car at two different speeds simultaneously. Obviously , it can't be done.
07-28-2011 12:10 PM
If this wonder board allows different rates on different input channels at the same time... wire the input signal to two channels and set up a seperate acq rate for each task.
Ben
07-29-2011 03:49 AM
ok thank you very much everybody. I ve tried the align and resample but I don t see any change. I would like to know how I can configure my express. For example if my high rate is equal to 20kHz and I want to resample this signal at 5kHz, What setting can i change for this? the dt ( and if it s yes what value)
thank you very much
Romaric GIBERT
07-29-2011 09:17 AM
Simple arithmetic. The dt for 5kHz is the reciprocal of it - 1/5000 = .0002
07-29-2011 09:31 AM
I will make some suggestions if I get your problem right.
I would firstly get the dynamic data and turn into waveform and record it.
You can use the same signal resample by using "Build Waveform" by changing "dt" value.
Here is a sample.
07-29-2011 09:39 AM
"... and this amp goes all the way up to 11 !" (Spinal Tap, the movie)
Ben
07-29-2011 09:54 AM
Here is a sample.
Not at all the same thing. A decimate or resample will reduce the number of samples, which is what I think the op wants. Just changing the dt will not reduce the sample size.
07-29-2011 10:31 AM
Sorry but I don t know what is the good solution, the solution with the VI Align and Resample or the solution has given Motorbeath? thank you very much
