accessing files on other computer
I am trying to access files from another computer and that computer is password protected. When I access the files from that computer I am getting Error 8. what is the best way to access the files from a computer which is password protected.
Mudda.
(4,300 Views)
How exactly are you trying to communicate with this other computer?  Are the files on a Windows network share, or what?  Can you access these files normally through some other method (that is, without using LabVIEW) ?
(4,291 Views)
I am just using normal Labview open file VI and getting  the error 8. The file is on another computer and I am able to access the files using the windows explorer. In windows explorer I give the computer IP address to find it and it asks for the user name and password, when I give that information I able to navigate through the explorer and find the files. I would like to know as the other computer is password protected what I need to do to access the files through labview.
thanks,
Mudda.
(4,279 Views)
Are you using Windows?  It sounds like the username used to log into the first computer is not recognized as a valid user of the second machine.  So it asks you to validate your credentials on the second machine.  (When you provide the username/password when it asks, do you use a different username and password?)
Try adding the username that was used to log into the first machine as having valid rights to access the harddrive of the second machine.
(4,277 Views)
All right, so the files are on a Windows network share.
What if you map the share as a network drive in Windows Explorer?  (Just go to the Tools menu of any Explorer window and select "Map network drive...".)  Can you then access the files via the network drive?
(4,273 Views)
I was able to access the files from the network drive. Whene ever I select the network drive to see the files, it asks for a user ID and passowrd. when i give that information it will navigate to the folders and I am able to access the files.
thanks,
mudda
(4,241 Views)
In my Open file VI when I selected Open (Read-Only) option, The VI opened the required file with out an error. Before I was using the option "Open". Thanks to all of those who commented on my question.
Mudda.
(4,228 Views)
