01-25-2007 08:00 AM
01-25-2007 08:06 AM
If your RT box has an onboard clock, then it should return the proper time after you set the time.
You can do this by using LabVIEW\vi.lib\addons\rt\RTUtility.llb\RT Set Date and Time.vi or by setting a time server for your target in MAX.
01-29-2007 03:56 AM
01-29-2007 05:14 AM
I don't know about the existing VIs, but using the first method is relatively easy. See the attached example.
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here, here, here, here and here are a few you can start with and here are some tutorial videos. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf).
01-29-2007 05:10 PM - edited 01-29-2007 05:10 PM
Message Edited by Simon H on 01-29-2007 05:10 PM
