06-17-2010 09:17 AM
Solved! Go to Solution.
06-17-2010 09:33 AM
What do you mean "the second one fails". It correctly indicates that 1 second has elapsed.
Using a flat sequence structure here is just silly. It does absolutely nothing that the wire between the first and second loop already does. Also, very bad idea to write code where you have to click on the Abort button in order to stop.
06-17-2010 09:39 AM
06-17-2010 09:46 AM
06-17-2010 11:46 AM
An Express VI for a greater than operation??? Come on NI. What the hell are you thinking? The only Express VI worth keeping is the Elapsed TIme function.
Which would you rather use:
