i currently doin a temperature control system using labview whereby my thermocouple is connected a thermocouple amplifier, because i connect using breadbord so the value i obtain is quite far from the data sheet given, so i need to do the calibration in order to show the temperature at my control panel accuratey, may i know got the graph function in LabView 8.0 can help to calibrate it without doin the calibration manually . The manually is for example cook the water then take the note down every 10 degree of the temperature that rising and then plot the graph and linearise it. Another question is my temperature function icon shown floating when i inputing the signal voltage to my usb 6008, got anyway to make it constant?
