Hello everybody,
I have a little question.
I have a Para_Machine.vi,
When I run this vi, it ask the the file which contains the last parameters .For example Para_Machine and when I Click on the button Enregistrer , It save the new parameters which I enter. In my file Para_MachineFile.txt, I separed the differents values with a tab Constant, but When I save the differents parameters, I don't know what I make for puting a tab ( see :in my block diagram , I indicate «The problem is here?????????????».
My second question is , I'd like to add in the file Para_MachineFile.txt one line at the start, which I Write the version n°1, after 2 , .... everytime which I'd like save the parameters.
Thanks you very much for your help,
