05-18-2019 07:10 AM
I am interested to zoom in to the mouse location pointed on an IMAQ image using the mouse wheel while I hold down the control key. Similar to how it is done in Windows.
Aware IMAQ ROI tool buttons have a zoom function that works exactly the way I want it to but I am interested to implement it through the mouse wheel event.
Any advise?
I am using LabVIEW 2013
- Sable
05-18-2019 10:04 AM
his is pretty easy to do with Imaq images using property nodes and an event structure. Below is the block diagram. I am just zooming in and out by a factor two but you can obviously change the zooming factor the way you want.
I am attaching the VI but it is in LabVIEW 2016 but I suppose you can recreate the block diagram using the image below.
05-18-2019 10:07 PM
Thank you.
