07-07-2015 12:11 AM
So a while back I asked if there was a way to be able to zoom in/out of a picture on the Front Panel. I was given the reply to use Zoom Factor and a user here even supplied me with a useful VI. And I've been working with this VI. It works well, but now I want to be able to do the same thing but with a PicRing instead of just a picture. But... when I connect the PicRing where the New Picture was connected, I get an error message:
You have connected two terminals of different types. The type of the source is picture. The type of the sink is unsigned word [16-bit integer]
....And I keep getting that error message no matter what I do. I'll keep trying but I was wondering if you guys have any ideas?
Review the attached pics for what I'm talking about.
07-07-2015 12:51 AM - edited 07-07-2015 01:10 AM
attach your actual VI! (use Explorer or Chrome if Firefox does not work)
By the way: why should it work??? A picture ring is not a picture control! Why do you expect that you can connect them with a wire???
edit: After some search on the forum, and looking at the property node options for a Picture Ring, it looks like, you can NOT dynamically change zoom factor of a picture inside of a Picture Ring!
But why do you need to use a Picture Ring? You could dynamically load any picture you want at runtime, and zoom in/out. So do not use picture ring if you want to change zoom factor...
07-07-2015 01:52 AM
You can also consider using array of pictures, have a look at this example:
