04-17-2014 11:56 AM
I'm trying to communicate with a Hart 1502 temp meter. It's easy and works with an interactive terminal (PuTTY, in serial mode) but does not work with LabVIEW. Well, as far as I know, the meter works fine but something is subtly different about the communications and I hope someone here can shed some light.
Basically, when I send "t\n" it returns a temperature and some other stuff.
I've been using the same serial-port VIs for a while and have had success connecting to a variety of other hardware.
Things I've tried:
0. Got out a DMM and checked the cable
1. Checked, re-check, re-re-checked the serial settings of the device. This includes rate, data bits, parity, stop bits, and hardware control.
2. The termination character from the meter is CR or CR+LF. I've set to CR+LF and set the VISA init function so.
3. I've tried sending "t\n" and "t" followed by "\n" in case the meter is confused by line-by-line input instead of character-by-character input. Shouldn't be a problem but it was suggested elsewhere so I tried it.
4. Re-starting the computer, in case of some unlikely VIAS issue
5. Used a co-worker's set of VIs for opening the port. Same issue.
6. Turned full-duplex on. At first, I observed only the echo of my "t" transmission but nothing else. Also, turned it off.
Does anyone know what's going on here? Even if you don't know, give me a homework assignment that could illuminate the situation.
I'm using the init, close, and first read-until-expected-string functions in the attached library.
04-17-2014 12:14 PM
04-17-2014 12:14 PM
Sorry, I can't se your code but sometimes its not what you send out that is problem but what instrument sends back.
Can you set up your code to just listen for characters maybe?
I think this can be done by sending en empty string to the write function and then using the read function to see if anything is in the buffer and just let it loop while building the response (if any).
If for example the device sends a string and more than one lf character
this could be a problem. Try disabling the termination char function and see if you can get visa to just display what if anything is in the buffer.
Hope this helps.
04-17-2014 12:17 PM
I forgot to say you could also use MAX to work with the serial port more directly..
04-17-2014 12:21 PM
Hello k15n1,
I'd suggest taking a step back and using the Basic Serial Write and Read example that ships with LabVIEW (Help>>Examples).
The function you indicated you were using appears to be looking for a very specific string (I believe you're using SerialPort_ReadUntilExpectedStringRecvd.vi), so if the instrument is returning something slightly different, you may not receive it. By default it's looking for "Hit any key to stop autoboot:"- are you providing a termination character or something instead of this? It's difficult to tell without being able to see the VI you're using that calls these functions. Either way, using the basic shipping example should give you a better idea of what, if anything, is being returned by the hardware.
04-17-2014 12:46 PM
As Dennis eluded to, make sure your string control/constant is set to use the "\ codes" display. It is in the right-click menu. Otherwise you are just appending the actual characters '\' and 'n', not the CR+LF you are looking for. Or just use the End Of Line Constant and Concatinate Strings to append the CR+LF to the end of your command.
04-17-2014 12:59 PM
Windows only for that trick. be careful if you have a MAC or Linux machine
04-17-2014 02:49 PM
I did not realize that my terminal program was sending \r\n. I was only sending \n in my labview code.
04-17-2014 02:54 PM
As suggested, I used the basic serial read/write VI from the help files. There was some weird behavior but at least it was receiving about the right amount of data. I fiddled with echo settings on the meter and turned off the "Enable Termination Character". A combination of these settings and adding \r to the transmission side of things fixed the problem.
Thanks for all the help with this problem!
