Xcontrol in LVOOP class?
I was wondering if anyone has successfully added an xcontrol to an LVOOP class.
 Brian
(2,447 Views)
Only if the XControl does not use ANY of the class VIs.  Otherwise the XControl will lock all of the VIs of the class.
Shane.
(2,436 Views)
Unfortunately, LAVA is down right now; but there was an interesting discussion there.
You should be able to see most of the discussion by doing a google search on "Are XControls In or Out? - LAVA" and viewing the cached version...
Now is the right time to use %^<%Y-%m-%dT%H:%M:%S%3uZ>T
If you don't hate time zones, you're not a real programmer.
"You are what you don't automate"
Inplaceness is synonymous with insidiousness
(2,428 Views)
Shane.
Ouch!
That would maen that if I had  VI open with the XControl I could not edit my class. What a pain taht would be.
Why would I want to do that?
Ben
(2,421 Views)
Well, the problem with two-way locking aside.....
It would allow easier debugging like being actually able to SEE what is passed into class VIs instead of a generic "lvclass" icon.
IIRC, it's a feature which is marked for possible future release (but not any time soon).
Shane.
(2,418 Views)
