04-13-2014 04:51 PM
Yes, I modified my VI and I send you the image of the results. On the image you can see the two xy graphs, in the left side, I plot the time stamp vs Power, in the second samples vs Power, I need to obtain the same result that appears on the second graph with time stamp in the x axis. You can see that in the first graph I obtain almost the same result but appears some mistakes on the data.
04-13-2014 05:01 PM
Hi, Dennis.
My excel files has the data that I use to create a time stamp for my new proccess.
I have an adquisition proccess from a energy quality meter, I save the info in TDMS files, so When I obtain data from a disturbance I need to analize this data. for that reason I need to create the time stamp from the excel file and plot the new results, my problem is obtain the graph.
04-13-2014 05:18 PM
in your thrid entry of excel sheet the time recoded is 150 and the time diff between your prev entry and this is 100 instead of 50 which is followed in all of your excel. so building waveform dt is not exactly 50
04-13-2014 05:39 PM
04-13-2014 07:22 PM
Thanks, I will review my files, but in general all the files have a dt of 0.05ms, maybe I delete this row when I created the example.
I proved the file without errors, all the samples have a difference of 50 ms, an my VI does the same.
04-13-2014 07:24 PM
what is a regular graph multiplier?
04-13-2014 07:32 PM
04-13-2014 08:14 PM
Ok, sorry I do not undertand at tha moment
04-13-2014 08:44 PM
04-13-2014 10:05 PM
I wrote the program, but at the moment I do not understand, I do not have enough experience with labview than you, I do not recognize all the labview terminology so fast, I am learning.
