XY Graph with many Y scales (I am using 6) going inside side plot area or hidden above one another.
Hi Guys,
I am having  XY Graph with 6 Y scales or less than that,where not all 6 scales will be visible in XY Graph sometimes 2 or 3 or 4,when this happen i could see the Y scales are going inside graph plot area and some time scale label going beyond graph or scales visible by overlapping .
attached screen of Y scale going inside plot area,
Pls suggest why this is happening and how to avoid it.
Also when using all 6 scales  the graph doesnt having scales arranged neatly and goes out or in or hiddenY scale going in and out.png
(2,864 Views)
Dskp,
If you could post your VI or front panel object we can try to take a look at what exactly is going on.  Before we spend time trying to fix this can you explain why you are sing 6 axis?  You may have a very good reason but I cannot think of a graph I have seen with more than 2 axis.  Are you going to be able to display this in such a way that the user will be able ot easily interpret the data within?
(2,858 Views)
Hi Jacobson,
Yes you are right,more scales are added play with data  ,but code is simple something a 6 boolean for 6 scales and if on its make scale visible and also user have to input the label name and max ,min and Units..attached the sample code...
(2,849 Views)
