XNET Error -1074384886 When receiving a 29bits ID Frame
i'm using XNET to send and receive several frame with 11- or 29 bits ID. In the attached vi you can see, i send the 1st frame 'Write1' into the bus, and then i would receive a 11bits ID frame, then i send two frames 'Write2' and 'Write3' one by one, then i also receive a 11bits frame as response. So far all things work good.
Then comes a problem: after the 'read2' when i send a frame 'Write4' which would have a response (read3) with 29bits ID, the vi can run correctly only once, then i must shut down the powersupply of my device before i run this vi for the second time, otherwise i will get an error (see attatched file) pops up. But if i send a frame which has a response with 11bits ID, this vi will always work good. Would you pls help me for this? Thx a lot.
(4,602 Views)
Accepted by mexaviesta
Why do you think that it is a XNET problem?
Are you sure that your device can receive your Write4 commad two times?
If you need to repower your device to be able to receive a reply back from one commad, then there must be a internal state/problem in your device.
Have you tried with other CAN programs?
Have your tried to use the XNET monitor to send the commands and see all the replies?
(4,593 Views)
thanks, as you said ,it's actutlly my devices problem. I need to put a 'reset' frame after the last frame, if i want to run this vi two times.
thanks again.
(4,576 Views)
