03-25-2013 10:41 AM - edited 03-25-2013 10:47 AM
I've been working with XControls a little, I find them a nice little way of displaying my class data...
However, I have this problem that when I load my project, I have to click 'Apply changes to instances' (as you can hopefully see in the picture) before I can run any of my VIs. Elsewise there are simply broken run arrows in my VIs.
It doesn't make a difference if I apply then save my project and re-open.
It seems to effect all my XControls but not always at once. The problem consistent if I open a project, close it and open back up but if I work on the project, save then come back, sometimes its the same ones sometimes its different ones...I can't spot any predictable behaviour ...
Maybe I'm missing something silly or someone else has come across this?
LabVIEW 2012 btw
Many Thanks
Nick
04-02-2013 04:29 AM
Hi Nick,
Welcome to the NI Discussion Forums, thanks for your post.
I haven't had this particular myself, but would like to investigate what is causing this. Does this happen with every XControl in any project? Or just this one?
If this only happens for this project (or similar ones) would you mind attaching the project in a reply?
