X410 Not Showing Up on NI Max
Hi! I'm working with the USRP-X410 for a project and am having trouble setting up the NI-USRP on my computer. I'm stuck on the locating the device name when running NI Max. I was wondering if anybody had this issue and if there are any solutions to this problem? Thanks!
Here's the link to the setup guide I'm referencing: https://www.ni.com/docs/en-US/bundle/usrp-x410-getting-started/page/getting-started.html
I'm stuck on the section, "Configuring the Ettus USRP X410 in MAX." It is not showing under my Device and Interfaces hierarchy tree.
(2,338 Views)
I think USRP device, including X410, cannot be shown in NI Max, if you connect USRP to your host with ethernet cable directly or through the network switch. You can try "NI-USRP Configuration Utility" to check your USRP status, and also these two commands: uhd_find_devices and uhd_usrp_probe.
If you click right on "Devices and Interfaces" and choose "Create New", then you can see that USRP's are not in the list to add. So, you are good to go.
But if you connect USRP through PCI Express connection, then you can see it in NI MAX.
I followed the same steps in the guide, and cannot see my USRP X410 in NI MAX, because I connected my USRP directly to host through ethernet cable.
BTW, could you run TX and RX examples successfully. I have runtime error, with error:
Code: 1359
Details: RuntimeError: Graph edge list is empty for tx cannel 0.
(2,226 Views)
