Wrong Data name after calculating mean ptbypt when saving to excel
In the attached VI, when I try to save data to an excel file, the labels (specifically: Differential Pressure, kPa, g/s, Density and so on) of my sensors show up as 'untitled 1', 'untitled 2', etc. I think this is because I take the average of the data using mean ptbypt, after the DAQ assistant, to eliminate noise. Is there a way to save the labels I mentioned above instead? Thanks
(1,985 Views)
Accepted by topic author Frappa11
You can use Signal Manipulation Palette>Set Attributes (QD: Set Dynamic Data Attributes, or right click the wire) to set the channel names.
(1,947 Views)
