Writing to a file
I have a file which works with a PCI-6024E card. The file is a loop that
reads the readings from a channel. Outside the loop there are 2 file
writes - 1 is a spreadshit file write with the data, and the other one is
also a spreadshit file with "header" - 3 numbers. The problem is that I have
a specified path to both of the files, but it keeps bringing me the file
save dialog, and totally ignores the path I specified. It pretty much
botheres me. Does anyone knows why it happens?
I have to mention that the data reading is OK, and after I save the files, I
get exactly what I wanted to get
(2,194 Views)
You already have some answers at http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=506500000008000000D02C0000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
if the problem is not solved, it will be helpful to post the VI or the problematic part of it.
(2,194 Views)
