Writing to a file longe signal
Hi
Can someone suggest how to write to a file longer signal (~30 min sample rat 1kHz ), I understand that I have to use a circular buffer, so my computer continuously acquire data in the background while NI-DAQ retrieves the acquired data.
I am using the 8.6 version.
Please advice
Yochai
(2,991 Views)
Accepted by topic author Yochai
I have done something very similar recently.  I used parallel loops that both communicated with the same circular buffer.  One loop put data into the buffer (a data-acquisition process), and the other loop took it out (to write it to a file).
The only gotcha for me was to make sure that the circular buffer didn't overflow (e.g. we don't want to write to it, faster than reading from it).
I implemented the circular buffer using a LabVIEW 2 style global (a.k.a. functional global variable).  The global is just VI that I could call that could either deposit data or remove data in the buffer.
This link should help you get started:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001EBrbCAG&l=en-US
http://www.medicollector.com
(2,978 Views)
Yochai,
i think that you will find that webcast very interesting.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,972 Views)
Thank you!
(2,954 Views)
