01-19-2014 01:06 PM
I'm wondering how to get the position of a stage I am controlling through labview to continuously write its position. I have an indicator set up with its position and the indicator shows the values as it moves along its axis, however when I try to save these values, only the initial value when I start the motion of the stage is displayed.
01-19-2014 03:04 PM
It would help if you posted your VI so we can see what you tried.
Most likely you need to create an array of the values and then write the array to the file.
Lynn
01-20-2016 09:34 AM
I am working on a relative motion program as well. May i inquire as to your mechanism for setting a start point and end point for your relative motion. I am also interested in tracking the motion. I have noticed that i run into the same problem when trying to initiate motion tracking with a jog type motion. It seems there is a problem identifying the instintanious posision during the jog.
01-21-2016 05:19 PM
the VI you attached has many sub VIs that are not attached and so there is not too much I can see. About knowing where you are while jogging. How are you initializing the jog? I see that you set the parameters for how fast you want to go, but it's not clear if there is a start button? a step button? or is jog continuous until you press stop?
01-25-2016 09:29 AM
Understood, what forums should i look under to keep working on my vi i cant find anything that seems to indicate motion vi forum. I dont think ill try to upload all the vi hierarchy to my vi right now.
01-25-2016 09:48 AM
