Writing and Reading Serial data Via ethernet (UDP)
Hi, I have established ethernet (UDP) connection between my laptop and a PC. My laptop is connected to an arduino uno and is getting the states of buttons. These states are transmitted via ethernet (UDP) to a PC. Once i run the receiver VI, i get the initial states but they are not being updated as the button states change. Once i stop the receiver VI and run it again then the latest states are displayed. Any help would be appreciated.
The sender VI (RTIO_UDP) and receiver VI (HOST_UDP) are attached.
(1,332 Views)
Can you make your front panels a reasonable size and reupload them please.
=== Engineer Ambiguously ===
(1,311 Views)
Hi RTSLVU, I've made them more compact if that's what you were asking for.
(1,293 Views)
