10-08-2022 05:32 PM
I have < a year experience using LabVIEW and this is the first time I've been asked to make a program that saves as a .csv
The issue(s) I'm having is-
1) Saving the selected booleans in their separate columns. Right now, it only saves the last one.
-I would also like to learn how to make each one of the tasks have a header so it can be filtered if needed.
2) The program saves continuously. Why..?
There are a few more bugs I'm aware of, I just haven't gotten rid of them yet.
TIA
10-08-2022 10:07 PM
Look carefully at the Write Delimited Spreadsheet function. I believe you have two of the (constant) inputs wired to the wrong connectors. If you fix this and run your program again, it may have other errors, but you should be able to figure those out.
Note that I am deliberately not showing you the "right way" to fix your code -- if you follow my advice above, and "fix it yourself", you will learn LabVIEW (and, more important, "Learn how to Learn LabVIEW") more "efficiently".
Bob "Professor" Schor
10-09-2022 02:20 AM
Did you really attach the file you wanted? That entire code is just pointless.
