01-07-2021 08:10 AM
Hello
I have created an automated test for a power supply that works flawlessly, it may not be the most efficient way to do it, but it works. So i am not seeking help to the testing program itself.
However i want to save the measurements into a test report (excel file) and i just cant figure out how to do it, i've played around with the write to measurement file and file i/o but without luck.
How do i write the test results from test indicator #1-18 into an excel file?
01-08-2021 03:17 AM
Hi Ignocia,
Excel can read a comma-delimited text file or a tab-delimited text file without any issues.
There's an example project "Tab-Delimited Data.lvproj" that shows how to write tab-delimited files; it's pretty simple code so I'd advise having a look through this. You can manipulate the strings to match your VI as needed.
Alternatively if you have the Report Generation Toolkit, you can find a significant amount of examples around this in the NI Example Finder by searching for "Excel".
Cheers,
Nick
01-08-2021 07:12 AM
I tried doing this with the write to measurement file. it almost does what i want. My problem now is that the signal index doesnt work as i want it to. I cant make new headers in the excel file. Can one of you help me understand how the headers work?
I attached the file
01-10-2021 11:22 AM
First a little advice:
Write data to a file like this:
01-11-2021 02:19 AM - edited 01-11-2021 02:21 AM
Thanks for the response RTSLVU.
Could you give me an example? I have tried using the normal file i/o blocks but never figured out how to make excel sheets and write headers etc.
Also what do you mean by dynamic data types?
01-11-2021 07:23 AM
Update: I figured out how to make headers and write numbers after the headers. Now how do i pull data from each of my cases and place them 1 by 1 in the excel sheet?
I attached my solution to creating the excel file and my measurement program.
