Write real variables from Labview 8.2 to Twincat embeded application
I am currently using Labview to write and read some variables defined through an embedded Twincat application.
I have defined the following variables in Twincat :
    Lab_lecture_real AT %MW100 : REAL;
    Lab_ecriture_real AT %MW102 : REAL;
    Lab_lecture_bool AT %MB1 : BOOL;
    Lab_ecriture_bool AT %MB2 : BOOL;
Based on the VI given by Beckhoff for Twincat ADS/OCX (http://infosys.beckhoff.com/english.php?content=../content/1033/tcsample_labview/html/tcsample_labvi...😃 , I succeed to read the variables "Lab_ecriture_real" and "Lab_ecriture_bool" and write through "Lab_lecture_bool".
Nevertheless, i failed to write in "Lab_lecture_real", which is a real.
I have enclosed my VI, everything seems to be correctly connected. Though, I don't understand why it works for a Boolean variable rather than a real one. Maybe the method used for writing a real is different from Boolean.
Could you highlight me on this subject, please?
Stephane
(2,381 Views)
Accepted by topic author Steffff
Why are you setting the length for the REAL number as 8 in the VI?
Is it in the documentation for the OCX somewhere else?
(2,371 Views)
I have just tried with the length for the real as 4 and it seems to work.
Thanks a lot for your answer !
(2,364 Views)
Since a Boolean is a 1, and a Real is a 4, it would indicate that the length is in terms of bytes.
(2,360 Views)
