Write a couple of strings and few fractional values to the same measurment file
I would like to write couple of strings and some measurement values in  the same measurment file.
Say for example:
First time the program runs, it performs a test and at the end of the test when user presses save it would save following line which is a mixture of strings and fractional values
1. UGS-544343     000000BSWS56    10.9  1.2   3.4   12.9    1.9   1.2  23.5  23.4   4.5  23.5   54.5
Next time test is run for a different measurement then it would append the existing file and would have second set of values added to the file.
2. UGS-948393     0000008SUS99       1.9   9.2   9.4   32.9    1.0   1.9  28.5  13.4   9.5  29.5   59.5
and so forth. I would also like to have all values tab limited.
Can anyone help me on this?
Message Edited by Mapatel on 06-25-2008 05:02 AM
(2,663 Views)
Hi Mapatel,
you can use the "Write to Spreadsheet File" function. Use the string instance and connect "true" to the append input.
Mike
(2,648 Views)
How about this?
Albert
Message Edited by albertm on 06-25-2008 10:59 AM
(2,647 Views)
Thanks Albert and Mike. Its working now.
(2,641 Views)
