07-22-2018 08:59 PM
Hi! We already installed Biomedical Toolkit for our Labview 2014 and we already seen some of the VI's of it in the palette. However, we cannot see the "Write Biosignal VI" under it.
We are aiming to save the TDMS of the acquired signal in the USB file path of NI myRIO. Is Write Biosignal compatible in NI myRIO? If not, is there any alternatives?
Thank you!
07-24-2018 09:22 AM
You should see the VI in the palatte in LabVIEW as long as the driver is installed correctly.
What operating system are you running? Windows 10 does not support the Biomedical Toolkit.
If you have acquired the signal already, you could use the regular TDMS write procedure.
Writing TDM and TDMS Files in LabVIEW
