Write Access only one channel in Analog Out in a task containing 2 channels with PCI-6259 Card
I am using an PCI 6259 Card for 2 Purposes at once,
Once I generate with one output an Sinus Wafeform on Analog Out 1
With analog Out 0 I control an other  device on a board.
I want to run them completely independent from each other.
Both functions are working when I use them by themself.
Now when I want to use both in one Software, I know I have to merge both Channels in one task.
How can I write access only one of these Channels without touching the current action on the other channel?
Thanks very Much
Sebastian
And for my system: LabVIEW 8.21, WinXP
(2,868 Views)
Dear Sebastian
Two channels within a single task share the same configuration settings,
i.e. they have an identical sample rate etc.
See the attached example for how you can make a task with 2 channels; to
adapt this to your needs you have to find a clever way for replacing one
of the source signals (e.g. 'Square Wave.vi') with your specific SubVI
(the one which "controls another device").
Best regards
Philipp R.
(2,854 Views)
