Word report with Cyrillic text
Hi all,
I've never used one of these forums before so hope I'm doing right.
I need to produce a word report with Russian & English text , if I set the system language to Russian I can type Russian characters in to word, but if I have a string constant in labview which I insert into a table in word the text from string constant changes.
Thanks for any help anyone can give.
(2,372 Views)
Welcome to the National Instruments LabVIEW forum. I am not really sure I understand what you mean, could you elaborate? Or give some screenshots of the behavior you are seeing?
Kind Regards,
Mike W
Applications Engineer
National Instruments UK&Ireland
(2,351 Views)
Hi Mike
Thanks for the reply.
The document that I will be working on hasn't been translated yet, so I took the string constant from UM_confirm Exit.vi http://digital.ni.com/public.nsf/allkb/24D845629A22AB6A86257473005ECF35?OpenDocument and wrote a small vi (see attachment) to see if I could put the Russian string constant into a table in word I separated the Russian & English strings and entered them into different cells in a word table. The Russian characters no longer look like Russian characters (see attachment 2). If I set the system language to Russian on the language bar I can Type Russian characters into word.
John B
(2,338 Views)
