Word report generation toolkit error with Win 7 LabVIEW 2013, Word2010
Hi All
I'm seeing different Errors using the Report generation toolkit. Maybe you can help me with that.
The errors are:
  • -2147417846, application is busy in Word_Get_range.vi
  • -2146824090 Exception in Microsoft word: Befehl misslungenHelp Path is wdmain11.chm and context ...
  • -2147417846 application is busy in Word_Quit.
the error messages are attached to the post.
I'm testing 10 sensors with one application and want to run up to 5 applications on one computer. Since I'm seeing such errors as application is to busy I set all my report generation vi's as non-reentrant execution and additionally added some pause after each word modification.
But I'm still seeing such errors when I run two applications on one computer.
What is the best way to deal with these errors?
thanks
best regards
Urs
Message 1 of 8
(3,307 Views)
You are going to have to post your VI.
Message 2 of 8
(3,302 Views)
My best guess here is that you have Word open and that is interferring with you being able to manipulate a document.
GCentral
Message 3 of 8
(3,285 Views)
in the first vi I'm saving the word document as a pdf and then dispose the report. the quite.vi is a subvi of dispose report.vi
The second attachment shows how I create the report.  I'm using a word_template which i update some tables, append text and include one figure. After each modification I'm waiting some time, thought it could help with these errors....
Message 4 of 8
(3,280 Views)
Post your VIs. NOT graphic files.
Message 5 of 8
(3,272 Views)
If I am running two applications and each one tries to creating a report could this cause the crash?
Message 6 of 8
(3,250 Views)
I don't know about a crash, but when I did a project with ActiveX and Excel, I had to add a prompt to tell the user to make sure Excel was closed before I could properly get the reference.  I would get an error if they had Excel open.
GCentral
Message 7 of 8
(3,243 Views)
Here my Vi's involved in creating the report.
Is there a way to check wheter word is busy or already open?
Message 8 of 8
(3,214 Views)
